| | | Forums66 Topics128,005 Posts1,055,263 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 37 | Will 6 hole buds from other makes of trucks work on Chevys?I have a tractor with a 1959 Chevy rearend that i use and right now i am use wheels from a 1953 army trailer. will ford and dodge wheels interchange? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Old Doug, as far as I know six bolt Budd wheels all have the same bolt pattern and should interchange between marques, the only caution I would add is to make sure the center hole is the correct size or larger for your intended application, hope that helps. | | |
