5 members (Gdads51, Otto Skorzeny, Bill Hanlon, JW51, Joe H), 100 guests, and 3 robots.
Topics128,101
Posts1,056,339
Members48,441
#110078 05/26/2004 7:51 PM
Anonymous
Unregistered
Anonymous
Unregistered
The handle which actuates the cowl vent on my 54 cab will not budge. Must have been installed by a union negotiator. I have disconnected the arms to determine if it is the top portion or the bottom portion that is inoperable and have have confirmed the bottom is the problem.
How is this supposed to function? Pull up-push down - turn it all around? If you had this problem how did you solve it other than sealing the vent? I think the vent is cool and would like to retain it.
I got rid of that vent. It was badly rusted and looked like a real leak source. Since I was going to put in ac, I felt no need for this vent.
Here's four shots of the cowl vent from closed to full open
[img]http://www.laroke.com/larryk4674/2004/cowlvent1.jpg[/img]
[img]http://www.laroke.com/larryk4674/2004/cowlvent2.jpg[/img]
[img]http://www.laroke.com/larryk4674/2004/cowlvent3.jpg[/img]
[img]http://www.laroke.com/larryk4674/2004/cowlvent4.jpg[/img]
liberal doses of penetrating oil over time may get it working again.
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
Anonymous
Unregistered
Anonymous
Unregistered
Thanks Larry, I will start the oiling process tonight.
On my 51, I cut off the nuts to get the unit out, then I used heat to loosen the mechanism. It seems to me that part of it remained in the cab, and I used "Fluid Film" on that part. When I put it back together, I used brass nuts. It works fine now.
1951 1 Ton Completed
The upper hinges were frozen on mine and took a lot of penetrating oil and slowly moving them back and forth and now they work pretty well. The lower one is a spring loaded ball and detente arrangement and I don't think it comes apart and probably a steady soak in Kroil or PB Blaster is your only option. Good luck
I took mine out and oiled everything up; tightened everything up; put a new vent gasket in, and it's working beautifully.
I have AC, too ... but I love using the cowl vent. Not only do I think it looks really cool in the open position, but it sure gives a real nice air flow inside the cab!
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
ODSS President
ODSS President
Nice pics Larry! I do all my high speed (65-75mph) highway driving with the windows closed and both vents wide open, cool ventilation and much quieter than windows open.
~ Cosmo
1949 Chevy Half Ton
Anonymous
Unregistered
Anonymous
Unregistered
I have succeded in getting the mechanism to function. Just took some machine oil treatments and a small pry bar to work it loose. Thanks for the help.
That's great! I luv it when a plan comes together!
Larry Kephart
Boca Raton, Florida
