3 members (RoadsScholar, Otto Skorzeny, 1 invisible), 197 guests, and 4 robots.
Topics128,108
Posts1,056,231
Members48,436
#1100744 05/04/2015 1:07 AM
I'm just finishing up my '67 shortbox, and I'm trying to troubleshoot my erratic gas gauge. Tank is empty, when I plug in the gauge cluster, the gauge goes way past full, like it's getting full 12v all the time. Tried a gauge from a spare cluster that I have, and the same thing. What haven't I checked?
Keith
If it were easy they'd have grade schoolers doing it!
Pakrat48 #1100760 05/04/2015 2:15 AM
3B Offline
Hy Pakrat48, are you saying this is happening by just plugging in the gauge cluster but not turning on the ignition?
Pakrat48 #1100774 05/04/2015 3:04 AM
I'm sorry, only when the ignition is on. With switch on I have 12v to the left side of the gauge. I didn't have my multimeter handy, but I put my test light on the sender terminal at the tank, and it lights dimly.
Keith
Pakrat48 #1100836 05/04/2015 4:43 PM
3B Offline
Hy Pakrat48, try removing the wire from the sending terminal of the gauge and with a jumper wire touch a known good ground for a few seconds and see how it affects the gauge reading. The gauge operates by varying the strength of two magnetic fields in the gauge, at the moment it would appear that only one field is energized in your gauge. It could be that you have a bad ground or open circuit to your fuel tank sending unit, hope that helps.
Pakrat48 #1100945 05/05/2015 12:21 PM
I'll try that 3B, the truck sat for quite a while, I'm gonna pull the sending unit out of the tank today. I think I might get a new printed circuit board for the gauge cluster. The old one seems a little brittle.
Keith
