7 members (Ribside, BarryP, Ol' Red, Donf, Rusted Nut, TomGMC, 3B),
95
Mod | | | Forums66 Topics128,134 Posts1,056,738 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 15 New Guy | | New Guy Joined: Nov 2014 Posts: 15 | I am trying to find stake pockets for my 1951 1 ton chevy truck. Anyone know where I can find them? I need all of them (think I need 8 in total for my long bed). Can I use the ones from the 3/4 ton?
Any info would be greatly appreciated.
| | | | | Joined: May 2011 Posts: 194 'Bolter | | 'Bolter Joined: May 2011 Posts: 194 | J_Wade,
I am assuming you mean the 9' stepside bed for the 3804 model. Starting from the front, the first & second stake pockets are the same as found on the 3/4 ton. The third one is just above the rear fender and is only about 3" deep (not available as far as I know). The fourth (and last) one is the same as used on the 3/4 ton and supports the tailgate. These are available from most of the vendors (except the short one). Hope this helps. Good luck with you truck. Tom
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Mar-K sells them, about fifty bucks each. Any reason you couldn't cut the short ones from a couple of full length ones?
dg
Denny G Sandwich, IL
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The short ones are nothing fancy. Measure the old ones and cut out and bend new ones from flat 16 ga sheet metal.
Grigg | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Didn't the center have the flare up into the bed side like the others Grigg? (your link to Webshots is dead you know.)
dg
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | yes, webshots died few years ago and I'm not chasing every link. The links in my signature do work.
I'd have to go look at my truck again to be sure, but I recall it being real plain, nothing fancy like the tall stake pockets are. | | |
