2 members (Phak1, HandyAndy),
149
Mod | | | Forums66 Topics128,275 Posts1,058,574 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 84 Shop Shark | | Shop Shark Joined: May 2008 Posts: 84 | Anyone have a picture or diagram of the correct clutch pedal linkage and mounting? Truck is a 40chevy 1/2 ton. Brake and clutch pedal bracket bolts to tranny and bellhousing. You can send image to 8315398928 or [email protected]Does the | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Do you have mounting assembly? I don't have mine mounted but can send a pic if that helps | | | | | Joined: May 2008 Posts: 84 Shop Shark | | Shop Shark Joined: May 2008 Posts: 84 | Sure anything will help. I need to figure out what springs are needed and if the clutch pedal hooks directly on the clutch fork | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I have a 41-46. It might be the same. If so there is an eye hook that connects to the clutch fork and has a cone shaped nut that rests against the fork. The hook end hooks on to the pedal arm. There are pictures in my photobucket but I don,t know if you can see that detail. | | |
