Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 135 guests, and 4 robots.
Topics128,275
Posts1,058,572
Members48,492
Anyone have a picture or diagram of the correct clutch pedal linkage and mounting?
Truck is a 40chevy 1/2 ton. Brake and clutch pedal bracket bolts to tranny and bellhousing.
You can send image to 8315398928 or [email protected]
Does the
I
I Offline
Do you have mounting assembly? I don't have mine mounted but can send a pic if that helps
Sure anything will help. I need to figure out what springs are needed and if the clutch pedal hooks directly on the clutch fork
I have a 41-46. It might be the same. If so there is an eye hook that connects to the clutch fork and has a cone shaped nut that rests against the fork. The hook end hooks on to the pedal arm. There are pictures in my photobucket but I don,t know if you can see that detail.
