BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
1 members (Hotrod Lincoln),
474
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,267 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Nov 2010 Posts: 35 Wrench Fetcher | Wrench Fetcher Joined: Nov 2010 Posts: 35 | hello can anyone tell me the original gold or champian looking color that most trucks 47-53 are painted inside cab thanks | | | | Joined: Jan 2011 Posts: 188 'Bolter | 'Bolter Joined: Jan 2011 Posts: 188 | | | | | Joined: Nov 2009 Posts: 639 'Bolter | 'Bolter Joined: Nov 2009 Posts: 639 | Look here,five pages of good reading. Also if you don't mind a very close rattle can paint, try Rust-oleum's Dark Bronze Metallic (#7272), I used it in the cab of my '53, check my picture link. | | | | Joined: Nov 2010 Posts: 35 Wrench Fetcher | Wrench Fetcher Joined: Nov 2010 Posts: 35 | | | | | Joined: Apr 2015 Posts: 4 New Guy | New Guy Joined: Apr 2015 Posts: 4 | I am also looking for the l953 Chevrolet interior color. Have you received an answer yet. If so , would you please share it with me. My paint company requested the GM paint code which I do not have. Someone sent me a PPG code of 33210 as the original champagne color of this truck. Thanks Billy Gibson
Restoring 1953 Chevrolet Pickup (5 window) that I purchased new.
| | | | Joined: Jan 2002 Posts: 2,696 'Bolter | 'Bolter Joined: Jan 2002 Posts: 2,696 | As like twotone, I also went with the dark bronze metallic and love it.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | The Dupont interior color code for 1953 cabs is shown on this page. The Dupont and PPG codes are also shown in the Stovebolt.com 47-55 Colors Tech Tip (look at the note, #13) Supposedly, there were at two or three interior color names between 1947-1953. | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | 'Bolter Joined: Oct 2006 Posts: 9,671 | Billy, did you read the link that twotone posted????? that and many other threads over the years have beat this to a pulp. DG
Denny G Sandwich, IL
| | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | Billy, did you read the link that twotone posted????? that and many other threads over the years have beat this to a pulp. DG You can post that again, Denny (and, you will most likely have to do so.) | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | Gas Pumper Joined: Dec 2000 Posts: 3,399 | PPG 27467 Graphite Brown Metallic is the correct color for all 47-53 standard cabs. If I am wrong, you will soon know.  | | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | That is correct (at least for 1953, that is what is shown in the Tech Tip), Deve
Have you bought that paint and check it compared to your dash?
| | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I have not. So please do not take my advice as the Gospel of all! However, lots of other bolters have used it and are happy.. that being said.. in all honesty, I am looking for the correct answer as much as you are Tim. Paint is expensive, and when I purchase a few hundred dollars of paint, I SPRAY it.. so I am concerned. I am about 6-8 months away from that step. I only paint after all the insects are dormant and I can expect my paint booth/garage to be somewhat clean enough and the temp is stable enough to spray. I need all the help I can get! | | | | Joined: Apr 2015 Posts: 4 New Guy | New Guy Joined: Apr 2015 Posts: 4 | Follow up on interior paint for l953 (3100) chevy pickup deluxe. Someone sent me some information indicating that PPG 33210 (Champagne) was the correct color and that Rust-oleum (spray Can) 7272 Dark Bronze metallic would also work. Can someone provide the correct formula. This person also indicated that there would be a plate on the firewall that would provide the exterior and interior paint colors but no such plate is on my pickup and I have owned it since l953 and know it could not have been removed. Is there a GM code available. HELP please
| | | | Joined: Apr 2015 Posts: 4 New Guy | New Guy Joined: Apr 2015 Posts: 4 | I have checked the charts from two tone and found them hard to decipher. The PPG Color Library has a new number 1-800-647-6050. They could not help me on the l953 interior. Howwever, when I pulled up a paint chart on my computer, it listed the following for l953 chevy pickup interior. Sheen Grey Poly (PPG)31104 Sheen Grey Metallic (Dupont) 202-81407 This site indicated that this was the color on all 1953 pickup interiors except the suburban. Hope this will be of some help and if anyone can confirm or offer better advise, Thanks
| | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | Shop Shark Joined: Jan 2010 Posts: 4,263 | Rust-oleum (spray Can) 7272 Dark Bronze metallic would also work. Sheen Grey Poly (PPG)31104 Sheen Grey Metallic (Dupont) 202-81407 This site indicated that this was the color on all 1953 pickup 7272 may not work for sheen grey poly or sheen grey metallic I believe it's more of a match for medium tan or dark tan from the chart on the tech tip
| | | | Joined: Aug 2011 Posts: 815 Shop Shark | Shop Shark Joined: Aug 2011 Posts: 815 | twotone, did you use clear coat over the Rusto 7272 on the dash? Mine is not this shiny. Steve | | |
