| | | Forums66 Topics128,139 Posts1,056,462 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 142 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 142 | I need a set of piston rings for a .020 over 302 GMC. Does anyone know where I can purchase a set? | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | With a 4" bore I would think that some of the online "speed" shops would have 4.020 ring sets. Take a look at Jegs or Summit for example. They might not be specifically spec'd out as 302 GMC but you're just looking for the particular dimensions for your pistons. i.e. 4.020, ring thickness, moly, cast iron, etc.
SimS | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Give these guys a call. I have bought a lot of stuff from them over the last 50 years. http://egge.com/ | | | | | Joined: Feb 2004 Posts: 29,819 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,819 | Ford, Chevy, MOPAR and a few other manufacturers all used 4" diameter pistons over a span of several decades. As long as the rings are the right thickness to fit the piston grooves, those rings won't care what brand of engine they're running in. Don't let somebody sell you some sort of outrageously priced rings when it should be possible to find over-the-counter items that will fit. Even if you buy a set of rings for a V8, it will probably cost less to discard a few rings than pay a king's ransom for a custom made ring set. Jerry
| | | | | Joined: Oct 2014 Posts: 142 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 142 | Thanks guys. I spoke to the people at egge and they have them at a reasonable price. | | |
