2 members (Samantha, Bill Hanlon), 134 guests, and 3 robots.
Topics128,186
Posts1,057,315
Members48,469
Hi all,
I've been thinking about this for a long time, and finally got it together and all done this weekend.
I wanted a secure, inside-the-cab hood release, so here are my build notes and pictures.
First, remove the front radiator cowl and hood latch, and make these cuts:
First cut the big cowling piece here
and cut the Latch piece here
Set them back together creating an open space
like this
Grind off the latch rivit and hammer pound it flat.
Cut it into two pieces, and place it together.
Original hole A, will need to be fattened up to match the size of the hole in the latch plate.
When you get it in place, mark where hole B will be drilled, the same size as A. C bolts together.
Drilled Flattened Latch Pieces
On the bottom side of the small piece, countersink the hole C. You will use a flat head bolt in here to hold these latch pieces together.
countersink latch piece
Bolt these two halves together now, and tighten the bolt.
latch pieces bolted together
Then your latch handle piece looks like this
new latch handle
Find a bolt that is the same size as the hole in the latch plate, and will fit your new latch, now that you drilled the latch hole bigger. Put the bolt up through the latch plate and add a washer, and some grease
bolt with washer
add a gob-o-grease
Install your new latch handle, and another gob-o-grease
install handle
Put another washer and nut. tighten down the first nut just until the handle doesn't wiggle. Add a lockwasher and another nut, and tighten them against each other.
locknut
Don't forget to drill a hole at the end of the lever arm
lever arm hole
Completed latch assembly, ready to install
completed latch assembly
I added an S hook at the end of the latch. I thought about an adjustable turn-buckle, but didn't have one laying around today. But I might add that later on.
latch handle S hook
Drill a hole through the radiator bracket
radiator bracket hole
Next, fatty up the hole in the corner of the radiator bracket. Don't drill into your wires running through there.
radiator bracket corner hole
Now it looks like this
radiator bracket
Put a bolt with a nut, up through the existing hole in the bracket.
nut and bolt
ready for a clamp
Drill a hole in the firewall. Not at the X. Better out toward the driver's side. I removed the hood springs a long time ago, but if you have springs, just drill centered below them.
Drill through the firewall here
Then drill an appropriate size hole in this handy bracket.
handy bracket
I got a six foot all purpose cable from my local FLAPS
for less than $7.00. ( see, almost free! )
Generic Cable release, six foot. Shorten, cut to fit later
Take the nut all the way off, then put the release cable only through the handy brake bracket, and then put the nut back on. Finger tight is gonna be good enough, because it's too cramped for a wrench. then poke the cable trough the firewall, run it along the fender, and through the radiator bracket holes.
run the cable like this. clamp to fender bolt at arrow
poke it through the radiator bracket holes, and clamp here, too
cable routing and clamp
then a quick spray paint, if you're so inclined...
quick toot-o-paint
Then, later, or tomorrow, flip the whole assembly over and attach the cable to the S hook in the latch.
attach cable
Now attach the super security metal panel, by adding nuts to the same screws that come down holding the latch panel to the cowl piece.
nobody's gonna get in here!
Bolt the entire assembly in place. It should work now.
all back together
oops, forgot. Drill a hole, or cut, to make space for the hood latch pin to clear as it pokes down through
drill or cut for latch pin clearance
Carefully close the hood, and give it a try!
Here . . . Pull on this
Nobody will be able to just reach up there and pull or push your super secure latch handle.
super secure latch cover
super secure latch handle cover two
Video. Check it out.
It Works!
You can view all the pics all at once in my photobucket
All the pics all in one place. Inside Hood Release
Sir Searchalot
Sir Searchalot
Good job Scot. Very innovative.
I bet I can still get in. Just need to push on the tab which comes up through the latch plate on the top?
Easy enough to fix.
Jim & Caroline
After thinking about this mod, if I lived in an area where I had to worry about someone getting under the hood, I would strongly consider moving.
My question is, why are we worrying about someone getting under the hood? A serious thief will just pull your truck up on a rollback and ease on down the road.
Scot, that is a real nice job. It takes some thinking to do something like that. Maybe you could sell the idea to someone. They would make all the parts with written directions and you could rake in the cash. Really, I think you did a nice job. Steven
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
