2 members (walterhvogel, klhansen), 114 guests, and 2 robots.
Topics128,035
Posts1,055,559
#1099163 04/24/2015 4:16 AM
I am restoring a 64 Chevy C-10. I have a 350 motor and a 700R4 transmission. The rear I have is a 3.42. Is that a good combination? I'm looking for something with good highway speed and lower rpm's. Not looking to race it.
pager #1099244 04/24/2015 9:14 PM
Riding in the Passing Lane
That is ideal.
1972 Chevy c10 Cheyenne Super
pager #1099249 04/24/2015 9:52 PM
That would give an OD ratio of about 2.40. That sounds high geared to me.
pager #1099305 04/25/2015 3:14 AM
Here is a bunch of good information,
http://www.jalopyjournal.com/forum/threads/[censored]-poor-mileage-from-a-700r4.972740/
I would think a 3.73 or 3.90 would be a much better choice. You have a heavy truck that is going to push a bunch of air at highway speeds, so if the motor doesn't make all its torque at very low rpm, you are going to have trouble with downshifting and poor milage.
joe
pager #1099320 04/25/2015 4:09 AM
You must remember that carbureted engines are happier at about 500 to 1000 RPM more than today's EFI engines. A 3.42 with OD would only run good down hill or with a strong tail wind.
pager #1099752 04/27/2015 9:35 PM
I have 3:38 rear gears in my 56 & a t5 with .73 O-drive. 350 stock engine. It will run up hill on the freeway all day long with out bogging. I had a 70 stepside with 3:08 gears, 350 engine & 700R4 trans. I have a long hill on the freeway going home from the shop. It will pull it at 70 MPH in o-drive with A/C on. These 350 engines have a lot of low speed grunt unless a guy puts too much cam in it.
pager #1100270 04/30/2015 8:57 PM
Thanks for the info. Right now I will try the 3:42 rear. Once I get this baby running, I think I might move to the 3:73. Everyone I spoke with said that would be the better choice.
pager #1100595 05/03/2015 12:03 AM
Crusing in the Passing Lane
The 3.42 might be good swapping material, too, although not many mountains in MD.
pager #1100881 05/04/2015 11:42 PM
I would think you would want to account for you tire size when you are doing this too. Without putting the tire size into the equation, you cannot get an accurate final reading of what your rpm's will be. There are all kinds of rpm calculators on the interwebs. They figure out your engine rpm based on tire size, transmission gear ratio, and rear-end gear ratio. I did a bunch of this when I changed out my 3 speed for a 5 speed on my car.
Matt
Blacktop Cannibals Car Club
1954 Chevy mild custom car
1955 Chevy second series 3200
