3 members (Cosmo, Wayne67vert, Bills Auto Works), 60 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1093508 03/24/2015 10:53 PM
I know swapping over to a s10 frame is common. There are a lot of Silverado/Sierras around here and it got me wondering: Is there a reason these frames aren't being used more often?
Because they are so wide an old truck looks goofy sitting on one.
The track width is too wide, your truck can end up looking like a 4x4
My 46 GMC on Photobucket
A Stovebolter, Sublime, did a 46 on a full size frame when I first joined the Bolt. He added a 4' strip to the fenders to widen the stance. It had a flatbed on the back. I can remember being awestruck at his fabrication ability. I looked him up here and the last post was in 2007. He had an excellent photo album but I couldn't get to. Probably like Webshots.....where I lost all my early pictures. Anyway pretty much anything you would like to do can be done but the beauty is in the eye of the beholder.
Dan
Hint: Measure both Frames, the wheel base and your wheel width, that can show you what you’re up against.
The newer engine placement isn’t going to mate right up with (you didn’t say)an older AD truck front end, engine compartment and radiator support.
Cross members, steering column, box and pedals will need a lot of head scratching too.
No one here will tell you it can’t be done, if you know how to Fab, weld and design what’s needed.
Define what you want out of your old truck; that can help point the direction your project will go.
Our 6.0Ltr engine, 14 bolt rear, going with a 4x4 dana60 front, pointed our project direction to re-frame.
Good Luck with your project, have fun and enjoy the challenge.
I don't know nearly enough to pull it off. I was just wondering why it isn't done more often. The amount of fabrication you all described clearly answers the question. Thanks smile
if your swapping an AD, you may get away with a big-bolt cab and front clip and a custom width bed (or at least wider rear fenders) you will still need to run severly negative offset wheels to keep them tucked in. Today's full size trucks are about 9" wider.
Track width of the AD is 58.1" Track width of the S-10 is 54" (The S-10 was based off the Isuzu P'up), track width of first gen Dakota is 60.7", Track width of a mid 80's C1500 is 65.8, track width of a C3 corvette is 59.6"
