2 members (klhansen, Otto Skorzeny), 47 guests, and 1 robot.
Topics128,036
Posts1,055,452
Members48,422
#1098838 04/22/2015 1:37 PM
Getting ready to install a new waterpump on a '54 235 engine.
I noticed three holes in the back of the pump and three holes in the
block... not counting the bolt holes.
The smaller 3rd hole in the block just above the inlet and outlet holes in the block goes nowhere. There is a matching hole on the back of the pump.
Why the hole if it goes nowhere into the block. ?? And, why would the pump have this corresponding hole?
1 1951 Chev Panel with a 350 small block, automatic tranny.
1 2004 Chev 2500 HD pickup... stock
1 1950 Chev 5 window pickup; 261 c.i. engine, 4 on the floor.
With lots of time and money, any Stovebolt can be restored.
The third bypass hole goes only a little way into the block, but then turns upwards through the head. This allows a small amount of water to circulate to the pump through the engine while the thermostat is closed.
My Blog
Dave:
The bypass hole was completely filled with rusty crud. I hand turned a drill
bit in the hole looking for a water exit. Found none.
What am I looking for? A pin hole or? Should the bypass hole be completely
drilled through the block?
The passage for the coolant is not "straight through" , its turns up into the head. Try bending a piece of wire or coat hanger so you can probe the opening. I don't have mine apart, but a flashlight and a mirror may allow you to see it.
Ron - - Dusty53
1954 Chevy 3604
Thanks, I'll probe for the opening at the top side of the hole.
Findings to follow...........
JB
Yep, found the hole after some digging. Lots of mineral deposits, rust and crud.
Who knew? Thanks Dusty 53 and Dave for the help.
While you're at it, remove the drain plug at the left rear of the block and run your wire around in there while running water through the block.
Will do cletis......thanks for the tip.
JB
