1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 3 Member | | Member Joined: Feb 2003 Posts: 3 | I have recently purchased a 1972 gmc pickup in great shape. The fuel tank is rusted and has gunk which is clogging up my fuel filter and my carb. Anyone with any ideas short of buying a new fuel tank(which I suspect I am going to have to do) I would appreciate. Thanks in advance. | | | | | Joined: May 2002 Posts: 32 Member | | Member Joined: May 2002 Posts: 32 | Don't know if you still need the info or not, but I got my tank cleaned out at a rad shop, they coated the inside and sprayed the outside and checked for leaks. This all cost me $90, now I don't know if the labour rates would be cheaper in the states (note: the u in labour is correct for us Canucks) but I figured that price was way better than getting a repro tank at 400 bucks or so. Be sure you call around first, as between different rad places it went from 90-180, and I had heard good things about the $90 place so I went with them for rep and price.
Lorne
MbOutdoors (Lorne) 1952 Chev 1300
| | | | | Joined: Feb 2003 Posts: 3 Member | | Member Joined: Feb 2003 Posts: 3 | | | | | | Joined: May 2002 Posts: 32 Member | | Member Joined: May 2002 Posts: 32 | You're more than welcome... did you go the Rad shop route?
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I've been using the POR-15 tank treatment system. Works great. Boiling out helps to clean it out, too.
Fred 52 3600 69 C-10
