4 members (MikeStone1953, Hawkman, Peggy M, Lostbuthaulinass), 68 guests, and 2 robots.
Topics128,057
Posts1,055,810
#109854 03/27/2003 12:57 AM
I have recently purchased a 1972 gmc pickup in great shape. The fuel tank is rusted and has gunk which is clogging up my fuel filter and my carb. Anyone with any ideas short of buying a new fuel tank(which I suspect I am going to have to do) I would appreciate. Thanks in advance.
#109855 04/09/2003 7:10 PM
Don't know if you still need the info or not, but I got my tank cleaned out at a rad shop, they coated the inside and sprayed the outside and checked for leaks. This all cost me $90, now I don't know if the labour rates would be cheaper in the states (note: the u in labour is correct for us Canucks) but I figured that price was way better than getting a repro tank at 400 bucks or so. Be sure you call around first, as between different rad places it went from 90-180, and I had heard good things about the $90 place so I went with them for rep and price.
Lorne
MbOutdoors (Lorne)
1952 Chev 1300
#109856 04/14/2003 7:19 PM
Thank you
#109857 04/15/2003 6:08 AM
You're more than welcome... did you go the Rad shop route?
MbOutdoors (Lorne)
1952 Chev 1300
#109858 04/15/2003 4:59 PM
I've been using the POR-15 tank treatment system. Works great. Boiling out helps to clean it out, too.
Fred
52 3600
69 C-10
