| | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | My 235 seems to be overheating all of a sudden. My temp gauge is new but seems to be broken...maybe by being over heated ? So I just ran my truck for about 15 min and left it at idle when I got home for a few minutes to check the block in various places with a laser pyrometer. Is that a reliable way to check for overheating ? Sure seems logical. Yep, it's reading 205 + on each side and top of radiator is 212.
The elec fan is set to come on at about 180 but it's not on. Also I guess could be bad water pump or thermostat...or ? The whole motor was rebuilt from the ground up last Spring | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | Mark, sounds like it might be the sending unit for the electric fan. Try jumping the terminals to turn the fan on. If that works, and the fan is not coming on at temperature as you describe, it is probably a bad sending unit.
Matt | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Electric fan not working and you wonder why it is over heating? Do you have a mechanical fan in addition to the electric one? What year is your 235? Carl
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | No Carl... I don't wonder. That's only one possibility. Sometimes it comes on and other times it does not. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | No Carl... I don't wonder. That's only one possibility. Sometimes it comes on and other times it does not. Yes reliable way, but not on radiator. Check block. Check inlet hose vs outlet hose on Rad. Many engines are at operating temp at 195-215 deg. Isn't electric fan supposed cycle on and off depending on it's own thermostat switch? (you say it works sometimes) What is answer as to if you have a mechanical fan? First thing to do it check "new" temp gauge and sender in a pan of water with a kitchen thermometer. You have to be sure if it's working or not. Use the laser also, so as to calibrate it at the same time. What exactly makes you think it is overheating?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | What made me think it's over heating is that the new temp gauge went max hot and now has stayed there....must be defective. So then I got out the pyrometer and checked all over.... Block after a 20 drive is 210 or so...different places show different temps but all high. Yes, I think the fan is in play here and no I don't have a mech fan. Does not seem to be room for it. My motor is 235 from 57 car... There is a fan shroud which seemed to help. It's been holding temp fine until this new gauge went south. I think ? that over heating can destroy these gauges. ??? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If it's an electric gauge, can't be hurt by heat. Mis-wire, yes. Mechanical gauge: don't think so either. Why are you blaming the gauge? May be the sender. Aye? At any rate, check them on the stove! My guess is that it is not over heating and I think that is what you are thinking also. Make sure timing is correct while you are at it. That can cause a little heat. If you have the correct radiator cap and thermostat and it is not boiling over like crazy, it's not hot.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | These are all mechanical and the sending unit, tubing, and gauge are all part of the same unit...no parts can be replaced. No not boiling over. Water pump and thermostat work OK... Fan may be the problem | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Probably. Sounds like you have a handle on it.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | If you want to go with a mechanical fan, you can make room for it and place it in the center of the radiator with an early style water pump relocation/adapter plate (search pre-'68 Dave water pump adapter plate), and a pre-'55.1 water pump (it sits higher than the '57) I have never been a big fan of electric-only cooling fan setups. I can tell when my fan belt flies off, but I can't tell the difference between if the electric fan shuts off because it isn't hot enough, or if it shut off because of a defective sensor/fan motor, and meanwhile the engine is overheating. Carl
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I would not want just an electric fan either and you have now seen why.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I wasn't happy with the system either. We looked at that re-location plate and it just didn't look good with so few attachments. We opted for elec only. Just had it fixed. It was the fan controller. I'll talk to my guy again and see what he thinks about putting in a mech fan and using the re-location plate...Big job but likely worth it. This controller lasted only a few years...not good. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Glad you got it working. That plate system Carl is talking about from Dave: lot's have used it, lot's have loved it. They say it's not hard to do if you have some mechanical skills. http://www.fiftee6.com/Water%20pump%20adapter%20plate%20install/
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I am familiar with the plate and it's popularity. My mechanic was not and was not sure it would hold up with limited mounting bolts. He talked me into the elec fan. Next time I need to tear down a bit I'll likel go with it and the mech fan. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | You need to change your bumper sticker unless you REEEEALLY want her !!!... LOL | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I talked to my mechanic yesterday about this plate and he told me that it won't work on my motor because it's a car motor. I had bought one but he couldn't see where it went and how it mounted so he called around and that's what he found out. He never mentioned that to me before....or I just plain forgot which is likely the case  | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Your mechanic should join this site | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | You should find a different "mechanic"- - - -he gives real mechanics a bad name! There's no difference in "truck" and "car" 235 engines where the water pump mounting is concerned. Jerry
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | That is just what he was told when he tried to research installation info. He doesn't specialize in this era of cars and trucks. Having said that, he has done excellent work for me for the past two plus years and taught motor shop at the local HS for several years before opening his own shop. | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | It just sounds like he doesn't want to work on an old vehicle and he's making up excuses not to. There's nothing difficult about the relocation plate- - - -it replaces the rear plate on a 216/early 235 water pump and requires drilling/tapping two holes in the front of the block. I taught high school auto mechanics for over 30 years, and just about any of my first-year rookies could have accomplished that job in a couple of hours. Jerry
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | It just sounds like he doesn't want to work on an old vehicle and he's making up excuses not to. There's nothing difficult about the relocation plate- - - -it replaces the rear plate on a 216/early 235 water pump and requires drilling/tapping two holes in the front of the block. I taught high school auto mechanics for over 30 years, and just about any of my first-year rookies could have accomplished that job in a couple of hours. Jerry There's no need to start trashing people you don't know a thing about... He does a darn good job but may have gotten bad info from somewhere. No one knows everything...not even you. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | In my opinion, your darn good mechanic (and I'm sure he is) needs to learn how to say, "I don't know" after someone introduces him to another way to solve a problem, especially one with the successful track record which this adapter plate has. Once he learns that skill, he will become an excellent mechanic. Carl
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Uhhhh, Carl. He did say I dunno and asked someone. Turns out that someone, whom he trusted at the time, maybe gave him bad info. How many times do I have to say this ??? Geeeze..
Drop this already... Da** this is a tough crowd...
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Well I don't know how tough this crowd is, and I will certainly drop it after this post, but you inquired about what you should do, implied that your mechanic gave you incomplete information on how to remedy the situation, and I tried to lead you in the right direction. It is entirely up to you what to do now. I meant no disrespect to you or anyone else. I'm just trying to help. Carl
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | | | |
