4 members (UtahYork, BC59, dt235sd, 1 invisible),
97
Mod | | | Forums66 Topics128,211 Posts1,057,469 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 30 New Guy | | New Guy Joined: May 2012 Posts: 30 | I have a question about running the 2 Rochester 1 barrel carbs with a choke on just the rear one. I have one really good carb and one the choke butterflies and top springs are crap so I was thinking about taking all of the choke system out completely butterfly, rod, all and just using the rear one as a choke, I know not the best way but seen several done this way and it doesn't get extremely cold here. Have any of you done this and what did you do about the holes once the rod is removed?
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Brads1951,
One choke connected (rear one) worked fine for me. You might want to consider somehow "tying"/holding the unused choke valve/flapper open but leaving the parts in place.
I dimly recall reading here that removing the valve/flapper parts somehow affects air flow.
Let's see if someone who knows carburetors clarifies/corrects this.
What size engines did the two Rochesters come from?
| | | | | Joined: May 2012 Posts: 30 New Guy | | New Guy Joined: May 2012 Posts: 30 | They came from 55-57 235. I have two 216 rochesters but their bolt pattern is the smaller ones that don't fit the Fenton intake. I looked for adapter but no luck and I don't want to have the intake welded up and redrilled. | | | | | Joined: Nov 2002 Posts: 2,777 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,777 | Tim is correct on the airflow. Having the choke butterfly functioning actually IMPROVES airflow at lower RPM (probably below 3500 or so).
With 2 carbs, both should be IDENTICAL for best results (unless you are looking for the absolute maximum WOT horsepower and have access to a dynamometer and some sophisticated individual cylinder temperature measuring devices).
Not saying it won't work the other way, because it will; just not as well.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: May 2012 Posts: 30 New Guy | | New Guy Joined: May 2012 Posts: 30 | Okay, I've read on other websites that some Rochester 1 barrel 216 carbs (everything but the bottom main throttle butterfly) can be exchanged with the 235 bottom throttle butterfly to work on Fenton intakes. Is this what most of you are doing to be able to use 216 carbs on the wider intake
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I passed on the Fenton and bought an Offenhauser because they came in either the big or small bolt pattern. That doesn't help unless you want to return the Fenton.
| | | | | Joined: Nov 2002 Posts: 2,777 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,777 | Okay, I've read on other websites that some Rochester 1 barrel 216 carbs (everything but the bottom main throttle butterfly) can be exchanged with the 235 bottom throttle butterfly to work on Fenton intakes. Is this what most of you are doing to be able to use 216 carbs on the wider intake Rochester spent the money for additional research, development, and tooling for multiple sizes because they were making too much money!  Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: May 2012 Posts: 30 New Guy | | New Guy Joined: May 2012 Posts: 30 | One more question should I run the carb isolators that were originally on the stock intake on the Fenton? Just needing to know ahead of time so I can order them if so since mine are all junk. I did already rebuild one carb 216 with the 235 bottom and it all bolted together perfect | | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | At this point, with mixed bases and unknown carb models, the spacers won't really matter. The dual intakes do not heat up as well as the stock intake since the carbs are spaced out away from the center heat. Spacers help cool the carb, you should not need them and they can always be added later.
