0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
Hi Everyone,
This is a follow up to last week's request for an inspection of my brake repair. It didn't go as I had hoped. So today, I got out there and redid everything. OBTW, these brakes are on my 1953 3100. So here goes:
Left Rear Brakes
Right Rear Brakes
New Drum
Please take a look and let me know if I got it right this time. I think I got the short pads right, by putting them on the front or primary side and the long ones on the rear or secondary side. The primary spring went on first followed by the secondary spring. On the right rear pic, you can see that the secondary spring kinda hooked onto the primary spring when it went around the post. I'm hoping that isn't a problem. I'd hate to have to take it off again as I did ruin the spring removal tool in the process of taking it off the first time to correct the pad placement....
Mike
1953 3100
The Gray Ghost
My Project journal
Only thing I noticed in your photos was the spring hitting the adjuster screw. The spring should have a long arm that "misses" the adjuster star.
Looks correct to me but I'm not a pro like some of the guys in this site.
1955 GMC 100 Series 2
3B Offline
Hy Gray_Ghost, the return springs on the right side pictures are intertwined and shouldn't be, be sure the butterfly piece behind the ends of the return springs is up on the post where it belongs. The left picture shows the outer return spring is barely in place over the post and that needs to be addressed also, check the butterfly piece again. In the right photo the small blue spring is slightly compressed, it could be that the parking brake cable on that side is a bit too tight, hope that helps.
On the trucks that are pre-self adjuster, the spring is supposed to touch the star wheel. That's what holds the adjuster from turning.
Bill Burmeister
