| | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | And it's getting really hot and smoking... what's the problem? Seems like a very simple concept. ..
1964 impala ss 1949 chevy 3100
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Is the starter getting hot/smoking, or just the switch on top of the starter? Carl
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Nothing on that foot switch would smoke...and it's a sealed can. If all connections are tight, it is simple, the starter is burning out. A disassembly, inspection, refurbish commutator, new brushes and bushings may save it. Rebuilt ones are available. It is usually easy to see where the smoke is coming from, as in: the starter case vents.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Time for a new switch. After taking switch off i touched positive to starter with pedeal pulled forward and it worked fine.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Not sure what you meant, "starter only engaging sometimes". The engaging is strictly mechanical. Anyway hope it works now.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you had the starter spinning with no load, that is not the same as under load, by a long shot. How did the contact surfaces look?
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Slip the cover/band off. Look at the brushes and commutator. If the commutator(brass segmented thing) is dark and rough it is time to get it rebuilt. If the brushes are short, then it is time to replace them. A good starter shop can rebuild it fairly cheap if the armature is OK. If the armature is burnt(from over heating) it costs more.
Steve H
| | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | I dont think its the starter or else it wouldnt work perfectly with switch off and pedal pulled in and touching positive to top post on starter. Turned engine over fine with starter switch off. Think it was grounding somewhere in the switch.
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | The switch is simple and robust. The brass contacts can wear and the paper insulators can go bad. The switch is available from lots of vendors and only 2 screws hold it to the starter. As you have discovered the "Bendix" is mechanical. If you can engage it it works. "Sometimes" working is probably the switch, and the contacts. New one is not expensive: http://www.classicpartsusa.com/product/EL102_1952/1952_Truck_Parts_Electrical Just one vendor, there are others.
Steve H
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | O'Reilly's even has them. I would inspect it's operation and condition and reason for failure but that's what I always do for future info and maybe fix myself. If it was "smoking" it should have bad JuJu inside. If your hot tab on the starter is worn, those are available too.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | After pulling it and inspecting it the contacts were very worn and the paper insulator was gone on the top post internally ( probably causing the arc). Ordered one off ebay for 11.95 will be here tomorrow.
| | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Update:
New switch came in the mail and starter works flawlessly.
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Wish I had paid $12 for mine. Up here I paid $35 plus 15% tax. | | |
