6 members (Hotrod Lincoln, wilbur53, Wayne67vert, HandyAndy, TUTS 59, 1 invisible), 76 guests, and 2 robots.
Topics128,205
Posts1,057,430
Members48,471
Finally getting started on the brakes. I have removed the master and wheel cylinders. Now I have questions.
I will be rebuilding all of the cylinders.
Question #1: The brake shoes still have some good meat on them. Any concerns about using them after sitting for 45 years?
Question #2: Bearings. They appear to be in great shape. No rust or anything. The grease that was in there appears to have turned into a "gel". Can the bearing be cleaned and greased and reused? If replaced, I am considering newer style roller bearings. Any concerns with the roller bearings? Where would you buy bearings?
~Justin
1937 Chevy 1/2-ton
"Wylburr Clyde"
More pictures on Google
My Grandfather bought it new and Dad drove it through highschool. The 3rd & 4th generations put it back on the road on 8/8/2015!
You can clean the bearings and inspect them. there should be no pitting or rough spots where the balls run in the race. I clean all the grease out I can with a rag. Next I use a small tin and put each bearing assembly in separately. I use some varsol or equivalent and swirl the tin around so the bearing spins inside. This removes all the remaining grease.
When I do my 38 Master brakes, I will have the shoes relined. The lining is brand new from 35 years ago but I don't trust it. I also like the idea of there not being any asbestos in the newer lining material.
1951 1 Ton Completed
Thanks Trucker.
The bearings look incredible. According to Dad, it is possible that the brakes and bearings were done right after the truck was parked in '69.
Question: What modern grease is recommended for the wheel bearings? What do the 'bolters use here?
~Justin
1937 Chevy 1/2-ton
"Wylburr Clyde"
Basically I buy a cup of grease that has a high temp rating and one that is approved for vehicles with disc brakes. What I'm using now is a yellowish color and you can save a couple bucks by using the store brand. Been doing it for 50 years.
