0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
Junior Member
Junior Member
How do you inspect a potential buy for rust?
I need some tricks of the trade.
bring a small fridge magnet with you. this works for putty/fibreglass as well. no stick no steel.
1961 Chev 3/4
1977 Chev Nova
Rust tends to hide in places you won't be able to see. Pull up the carpet and inspect the floor for signs of warping/cracking. To do a thorough inspection, you'll need a jack, jackstands, creeper, flashlight, and a "mirror on a stick."
Heamil is correct, you can wrap a magnet in a handkerchief and drag it along the body panels; when it falls off you've found the bondo.
On most older vehicles, you can check the body to frame connection by rocking the car side to side. Rotten body bushings will often make a gruesome squawk when stessed.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
