8 members (Gdads51, Wayne67vert, MickeyP, Cletus1950, Hotrod Lincoln, UtahYork, TexasJim50, baldeagle), 106 guests, and 2 robots.
Topics128,179
Posts1,057,068
Members48,460
1940 PU............
[email protected]
Should be able to get them at any fastener place like Fastenal. All you need is to have the correct diameter as you can cut to length. Head size might need trimming to match original. Take an old pin and match it up. What they won't have is oversize pins to compensate for wear: example 5/16 plus 0.003 like antique parts suppliers do.
Evan
I found some for my 38 Master at the local flaps. They had one of those shelves with various common parts and these were for a late model F**d product. They are too long but the have the correct diameter.
1951 1 Ton Completed
burrpenick, if you don't find them drop by a regular machine shop and have them turn you a couple out of some cold roll steel. They will simply take a piece of cold roll and turn it down to what ever size you want including leaving a head on it. That way you can get one oversize if you need it....but first make sure your hole is OK or drill it out straight then have one made......just another option if you don't find one.
