| | | Forums66 Topics128,174 Posts1,057,047 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | 1940 PU............ [email protected] | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Should be able to get them at any fastener place like Fastenal. All you need is to have the correct diameter as you can cut to length. Head size might need trimming to match original. Take an old pin and match it up. What they won't have is oversize pins to compensate for wear: example 5/16 plus 0.003 like antique parts suppliers do.
Evan
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I found some for my 38 Master at the local flaps. They had one of those shelves with various common parts and these were for a late model F**d product. They are too long but the have the correct diameter. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | burrpenick, if you don't find them drop by a regular machine shop and have them turn you a couple out of some cold roll steel. They will simply take a piece of cold roll and turn it down to what ever size you want including leaving a head on it. That way you can get one oversize if you need it....but first make sure your hole is OK or drill it out straight then have one made......just another option if you don't find one. | | |
