1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1097064 04/12/2015 9:33 PM
Hi Everyone,
I've started the actual rebuild of the brake system on my 1953 3100. I started with the right rear brake assembly. I would appreciate everyone taking a look at the pics and let me know if it looks like it is supposed to look. I know that sounds a little weird or that I'm lacking confidence, but this is the very first time that I've done this. So I guess I do lack self confidence! Anyway, here are the pics:
Overall view of brake assembly
Rear shoe hold down
Shoe adjuster
Front shoe hold down and anti rattle spring
Return Springs
Sorry that the pics are a little blurry.
My concerns really revolve around two things: 1. Are the pieces put back together correctly? 2. Are the return springs seated well enough or will they work loose during operation? It just seemed to me that they should have been sitting a little deeper behind the post.
Go ahead and give me the bad news if I did it incorrectly. I want these to be right, so no pride here, just be gentle.
Thanks for looking!
Mike
1953 3100
The Gray Ghost
My Project journal
H Online: Content
The assembly looks OK, and the high ride on the return spring over the anchor post is normal. The anchor post is tapered, so the outside spring rides higher. It's also assembled correctly with the rear shoe return spring to the outside. That increases the tension on the secondary shoe spring just a little, and also provides an anti-rattle effect by pushing the springs back against the plate over the tops of the shoes. I'd suggest taking a pair of pliers and squeezing the spring eyes shut a little to keep them from jumping off the anchor stud. Have fun!
The springs and hardware look like they're in ok. However, you have the shoes on backwards if that's the right side. The long shoe should be at the rear of the brake assembly, and the short show goes to the front. Not really a big deal, just need to swap their positions. It's actually quite common to see that happen, even among "mechanics" claiming to be "professionals".
Bill Burmeister
He sits at computer with dejected look on face.... Those springs were really hard to get on!!! Oh well, I'll chalk it up to a learning experience.
Thank you for taking a look! I'll post a "victory" pic next weekend after I swap the shoes around!
Mike
1953 3100
The Gray Ghost
My Project journal
What kind of tools were you using to remove/install the springs?
Bill Burmeister
I was using one of those multi tool brake tools from my flaps.
Brake tool
Instruction said to use the end with the groove carved out and roll the spring onto the post. Was easier said that done, as those springs were brand new and tight!
Mike
1953 3100
The Gray Ghost
My Project journal
Ok, just was curious if you had the proper tool for the job. Once you get the hang of it, that tool isn't too bad to use. It's certainly easier than trying to use a screwdriver or other similar tool to get the springs on.
Bill Burmeister
Now I've got to figure out how to use the other end of the tool to get them off again! Oh the joy of it. headscratch
Mike
1953 3100
The Gray Ghost
My Project journal
Sir Searchalot
Sir Searchalot
Just to be sure I read you right and you read the instructions right. Regarding the picture of your tool. One of the lower arms in pic is for installing spring (right hand arm in pic) and the other lower arm in pic is for removal (left hand arm in pic).
Left hand barrel is twisted/rotated to release spring from post.(one way for one spring, other way for other spring). Right hand is used to install by attaching one end of spring to shoe and sliding other end of spring down the tool arm and over post by placing arm into spring hook and at the same time placing end of tool (groove) over post and lift and move arm at proper angle to cause spring to slide onto post.
I use the upper two arms to install self adjuster spring. There is a separate tool for the shoe retainers/hold downs.
H Online: Content
Good catch on the front/rear shoe length- - -I was looking at as if it was the driver' side brake.
The plier-shaped end of that tool is for working on Lockheed brakes (early Ford and Chrysler) with one long spring across the top, attached to both shoes.
You got it! I was using the long, untwisted end (on the right in the pic) for installing the springs. Still, being new springs they were very difficult to get over the post and in place. I'm actually a bit worried about taking them off next weekend. Worried that I might lose control of them and send them flying into something, like my skull. So I think I'll add a face shield in addition to my safety glasses when I do the removal! Better safe than sorry. I am decidedly uncool at this stage, I think I'll take them apart piece by piece and try to get it right this time. chug
Mike
1953 3100
The Gray Ghost
My Project journal
Sir Searchalot
Sir Searchalot
Yes it is hard to do sometimes. You need to tap on the spring to get it to go down the arm. Good Job!
Thank you for that last bit of info (tapping the spring to get it to go down the arm)! I thought I was just being a bubba when I was doing that today! Glad to hear it's normal!
Mike
1953 3100
The Gray Ghost
My Project journal
I thought it was the driver's side too but in one photo I can see where the emergency brake cable is attached to the arm, on the left of the photo.
1951 1 Ton Completed
I use vise grip pliers and two-arm muscle the springs on and off. I could never get the hang of the specialty tool without gouging up the shoe.
Carl
Carl's advice is good advice.
I practiced using the spring tool for sliding on the spring and the other end for removing the spring. Most of the time it works like a charm. When it does not work, I save my special incantations (#$@&%*!) and use a vise-grip pliers.
use of the tool - spring removal and spring installation (probably also shown at a link above)
Awesome video! I liked the "hat cam", too. He made using the tool look very easy. Either way, easy or hard, I'm going to be back at it next weekend and I'll post my results then. Wish me luck!
Mike
1953 3100
The Gray Ghost
My Project journal
