4 members (Mike Burns, Youngin' Tut 59, Hotrod Lincoln, Hanks custodian), 74 guests, and 2 robots.
Topics128,066
Posts1,055,871
Members48,428
#1096552 04/10/2015 4:25 AM
I know that this has been discussed several times but have never been able to get a good answer. I am looking for a 1/2 ton, drivers side spindle for my truck. If anyone knows where I can get one, please let me know ASAP.
Nate
Nate_L #1096560 04/10/2015 5:15 AM
What year?
My Blog
Nate_L #1096608 04/10/2015 2:53 PM
I believe a 1952.
Nate
Nate_L #1096627 04/10/2015 4:44 PM
You could try eBay (51-59, I think).
Or, place a Want Ad in the Swap Meet.
No one makes a reproduction spindle/knuckle.
You might find a NOS one, but that might take a while.
You might find a good used one - make sure you ask if the floating bushings just float (you do not want them wobbling).
Nate_L #1096678 04/10/2015 10:47 PM
1941-50 1/2 ton spindles will also work if you drill the two lower bolt holes from 7/16" out to 1/2".
1951-59 are a direct replacement.
My Blog
Nate_L #1096696 04/11/2015 1:35 AM
Thanks guys! I'll post a wanted add to see if I get any hits. I have a 3/4 ton axle with spindles, so I may take them off and take them to a machine shop to have them turned down to the 1/2 ton size.
Does anyone know the exact specs of the 1/2 spindle, that I could give to the machine shop? I'm taking them the 1/2 spindle so they can measure it, but I was wondering if anyone had the specs too???
Nate
Nate_L #1096724 04/11/2015 2:46 AM
You should have no trouble finding a good used one. Even if the axle is in a growd up fence row, the working parts of the spindle are smothered in grease.
Carl
Nate_L #1096761 04/11/2015 4:02 AM
Nate, it is a little more than the spindle diameter difference between 1/2 ton and 3/4 ton. The bushing size is also different, and I suspect the 3/4 ton spindles are also longer.
My Blog
OK thanks. I think I am on track to get another 1/2 spindle. I've have several guys on here checking to see what they have. I think this would be the cheaper way too.
Nate
Nate_L #1096823 04/11/2015 2:52 PM
"You might find a good used one - make sure you ask if the floating bushings just float (you do not want them wobbling)."
Most steering knuckles that have been sent to me were no good (very loose bushings - a very common malady). Some of the sellers gave all my money back. None of them asked me to send one back (they said to throw it away). Try to find a seller who knows what to check-for and will guarantee the knuckle is useable.
Will do, thanks for the advise. I'm looking to find one from some of the guys on this site. Hopefully they will find one that will work...
