4 members (32Fordpuchoptop, 55shaker, TUTS 59, 1 invisible), 70 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
#109646 04/21/2004 11:00 PM
Anonymous
Unregistered
Anonymous
Unregistered
I seem to recall hearing about a specialized tool for removing spot welds other than the good ole twist drill, pry bar, hammer or hot wrench. Can anyone point me towards this mystery tool or share their secret techniques for separating the numerous spot welds found on AD trucks?
#109647 04/21/2004 11:04 PM
Anonymous
Unregistered
Anonymous
Unregistered
#109648 04/22/2004 12:24 AM
Z
Z Offline
eastwood too.
#109649 04/22/2004 2:37 AM
I got a nice one off the MAC tools truck, about $30. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#109650 04/22/2004 2:49 AM
Any autobody supply store will have them. Matco tools has a set of varying sizes on sale this month.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#109651 04/22/2004 3:34 PM
This is what I use everyday at work. They are about $400.00 so too much for a home hobbiest but if you find yourself doing a lot of projects with spot welds, I HIGHLY recommend it. It has a few different "clamps" that go behind the weld with up to about six inchs of depth.
Basically using this tool or not you have to look at drilling out spot welds as "unbolting" the part. If you were unbolting the part would you start prying on it with a chisel BEFORE the bolt was out? No, so don't do it with a spot weld either. Take your time and drill STRAIGHT into the spotweld completly removing it. If the weld is bigger than the drill than make two (that is all it usually takes) offset cuts. Place it so it cuts about half the weld then move the drill over so you can cut the other half and not have the centerpoint "in" the first cut. This will usually prevent the drill from walking. If you try right in the middle and then try cutting a little weld left you will likely have the bit walking and screw up your bit and the hole.
Drill it out without hitting the bottom panel too much. But really you can strategically drill right thru both panels and then use that hole to plug weld your new panel on. So SOMETIMES it is not nessisary to use a spot weld driller at all. Though I always do because I have the need tool that does all the work smile
After you have drilled out the weld, I have found the BEST tool for spliting the panels is a gasket scraper! You know the real nice ones (I have been using a Snap On one for about 15 years) what looks like a screw driver but has a "blade" at the end about one inch wide. They are thin and slip between the panels tapping it on the handle with a small hammer you slip the tool up to the spot weld (something will sometimes be left of the weld that you have to break) and tapping the hammer on the handle a bit more will run it right thru breaking the panel apart.
It is one of the very few times I will use a tool for something besides what it was intended. smile It works like a charm.
[img]http://members.aol.com/basicofbasics/spotwelder.jpg[/img] [img]http://members.aol.com/basicofbasics/spotwelddrilled.jpg[/img]
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#109652 04/22/2004 9:22 PM
Looks like a rivet shaver.
#109653 04/23/2004 4:43 AM
The pros use a special air drill, it has 2 legs to keep it from skidding around has a depth stop and runs at the right rpm. Perhaps more than most people want to spend but nice.
I used to own a tool like this when I worked in a body shop. It was called a "Spottle". Excellent for drilling out spot welds. Panels practically fell off after drilling.
JS
"I can go anywhere...for I am a Piewagoneer...To the Piewagon"
1966 Chevy Panel Delivery 1966 in the Gallery and more on Webshots
#109654 04/23/2004 9:46 PM
Anonymous
Unregistered
Anonymous
Unregistered
Thanks for all the suggestions. Although probably the right thing to do, spending $400 for another tool would be a bit over the top in my wife's opinion. So far she has given up her side of the garage for the last 16 months and if I spend more on one tool than I spent on the truck in the first place I have to give up my side of the bed and start using the bed of my truck for sleeping. I like to push the envelope in life but there is a limit. I will try the single bit route and get on down the road. I can probably get that bought under her radar.
