2 members (Otto Skorzeny, Rusty Heaps), 134 guests, and 2 robots.
Topics128,101
Posts1,056,182
Members48,436
#1096273 04/08/2015 11:23 PM
After pulling the axles on my '53 3100 1/2 ton, I noticed a shallow groove on each bearing where the bearing or seal would ride. I took them to let my mechanic look at them and he said to install axle saver bearings. What do you guys think about this? Anyone here used them? Thanks.
Gas Pumper
Gas Pumper
I have only heard of this, never seen a set, but you can also use a speedi sleeve. Its a stainless sleeve that very tightly fits over the axle. Its made to give the original seals a nice smooth surface to ride on. Just giving you another possibility.
I have a 1950 and my go-to guy said what yours said. After doing more research, the axle savers weren't available for my axle shaft.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Did the axles have the original leather seals? Sometimes the new style rubber seals ride on a different portion on the axle shaft.
I used axle savers on my '69 axles. The didn't leak past the seals any longer. Now they leak around the o-ring on the outside of the axle saver!
Carl
Gas Pumper
Gas Pumper
No, Denny, I am the one advocating to use a Speedi Sleeve. But the last ones I got from a jobber were about $48.00 each. I am sure you guys can do better than I did. They work great but they are tricky to install.
Mine were SKF 99187.
The axles used were out of a 55 1st series so open driveline, newer style.
Deve
The Think Tank
SKF 99187 - $24.79 from Rockauto
Does anyone know SKF part number for a 1953 axle?
I have used them - they worked on slightly worn axles.
I have used them with no problems, solved the worn axle problem.
Joe
Gas Pumper
Gas Pumper
You will need to measure your axles to make sure you get the right speedi-sleeve. I had someone else put them on for me. Reason was because in reading about this, you need to put the axle in a freezer for about an hour for best results. My wife would KILL me. They are VERY VERY tight and if they stop in the wrong place, you are screwed. The freezer is good insurance.
Then, you need to know exactly where the sweet spot of that sleeve needs to be. It scared me enough to just pay the $50 to have them installed at a local shop. They did a great job.
Deve
The Think Tank
You can search for an item by manufacturer and then item number on Rockauto.com (top menu "Part Number Search")
Search for Part # = '99187' and Manufacturer = 'SKF'
http://www.rockauto.com/catalog/raframecatalog.php?tab=search&mfr=SKF&partnum=99187
Riding in the Passing Lane
The axle saver brgs don't fit these axles. They work on 63 up.
1972 Chevy c10 Cheyenne Super
If the grove is caused by the axle seal, install a new seal and shim it out a little ways with a piece of wire. So it will seal on a new spot on the axle where there's no groove.
Brian
1955.2 3100 Truck
I like that idea right there! Pure farm fix!
Carl
Thanks for all the replies.
