1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
I am not getting any clutch feel from my 61 original granny 4 speed. It doesn't allow me to shift in or out of gear. The clutch/brake reservoir keep loosing fluid and I believe it loosing the brake fluid through the slave cylinder. Does anyone have any idea?
Also, does the is the slave cylinder inside or outside the transmission.
Thanks.
1961 Long Stepside Apache 10, original 235, 4 speed and 3:90 posi totally stock (owned 12 years)
1966 Chevelle (owned 53 years)
Sir Searchalot
Sir Searchalot
It should be outside on passenger side. Bolted to Housing. Easy to bleed, easy to change. Find the drip.
Thank you
Sir Searchalot
Sir Searchalot
Hope you get it done Ok.
