0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#109599 03/16/2003 3:17 AM
V
V Offline
While doing some cleaning inside the cab, I notice a steel channel thing going around the doors, spot welded to the cab. What with this ?
Looking for info/victor
#109600 03/16/2003 3:23 AM
That channel is where the cab windlace goes. It is a rubber seal that helps to seal the door against the cab.
#109601 03/16/2003 4:04 PM
V
V Offline
Russell thanks for the info. I wonder if this seal is really needed. With a new door seal it should control most of the wind. I know that GM put these on for a reason, I wonder if its over kill??
#109602 03/17/2003 9:19 PM
V
V Offline
_NO_ it is not ' overkill ' ! . anytime you get side winds the wind will blow right through the doors .
Most of these trucks are missing it as it wears out fairly quickly from abrasion .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#109603 03/17/2003 9:39 PM
Quote
...and spray rain in your face.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#109604 03/18/2003 4:35 AM
Junior Member
Junior Member
a little frustrating to put on, at least for me. I only have one door on right now. Unfortunately its the passenger door. Best thing I have found is to spray a LITTLE WD40. It still took me several retries to get it on. But I think it is worth it.
54 1ton
#109605 03/18/2003 4:41 AM
I've done it to a couple rigs now and believe me, once you've installed it you'll be happy that you did. Not only does it stop the wind from coming through but the interior looks is topped off perfectly with this. The only trick is if you have a spotlight, you need to cut into the windlace a lot. Otherwise, you'll go to bed that night with a smile on your face.
Victor, when do we get to see a jpeg of your beast?
Craig
#109606 03/18/2003 7:45 PM
WD-40 makes the rubber slide, but it also breaks down the rubber and leads to premature rot. Do not use petroleum products on rubber unless you want to do the job again soon. I tried liquid dish soap with little success; it's too tight a channel with tight bends and the soap dried before I got the windlace all the way in. I bought a can of spray silicone and dosed the tracks repeatedly as I slid the windlace in; it slid into place with minimal effort. smile
#109607 03/19/2003 2:17 AM
V
V Offline
Took some pitures, have to try in morning again.
Going to good guys Pleasanton this weekin. Going to check out frames or chassics. I see that RB's has a new one about 7400.00. Have not told the wife yet. I hope they have show specials. anyone else going to pleasanton ?
#109608 03/22/2003 6:30 AM
Victor,
Tony M & I will be also at Pleasanton. Look for a couple strange lookin kinda guys.....
Craig
#109609 03/24/2003 7:49 AM
V
V Offline
Went to Pleasanton, had a nice time. Sold a few toys(Diecast)and got two nice catalogs for the 50.
RB's and truck shop. RB's didn't bring their rolling chassic, wanted to check it out. I think thats the way I'm going to go. This will save me a lot of time and running for parts. Anyone out there done this yet??
