| | | Forums66 Topics128,271 Posts1,058,414 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 22 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 22 | I ordered a mustang ii kit from speedway, and I have the frame all stripped except for the stock axle! I can't seem to find anyone who has the right measurements for the axle center line for a reference! I have seen on the TV show trucks 20 15/16 from the end of the frame to center. Then speedway has instructions saying to measure from front shackle hole, 18 1/8 but neither one match my center line! Can anyone help me!
Guillermo Ortiz Jr.
1950 Chevy 5 window with a 54 GMC cab swap
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Guillermo,i'm just about to go to my garage to strip my front end,I have a Speedway MII IFS in my '50,if you can bear with me i'll get some measurements for you.
I didn't install the crossmember personally but I have a sneaking suspicion the installer fitted it slightly forward of the recommended location.
I'll let you know. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2012 Posts: 22 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 22 | Ok thank you. If you don't mine taking a bunch of picture for me also. You can send them to my personal email. [email protected] .
Guillermo Ortiz Jr.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Guillermo,sorry for the delay,as I suspected the measurements are off from Speedways. I can't even talk to the guy that installed my crossmember as to why he fitted it further forward. We don't talk any more as a consequence of some other 'issues' with other work he did to my truck.
That also explains why my chassis didn't need clearanced for the steering rack arms! How far off are the Speedway measurements from the stock axle centreline on your truck?
| | | | | Joined: Jul 2012 Posts: 22 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 22 | Actual centerline on my truck is 21 3/16",and what speedway wants is 18 1/8"! So 3 1/16 ish!! Different which is a lot in my book!! So then I talked to a few hotrod builders and they all told me strip all of the old parts off. Then put the front clip back on then get a set of wheels around the size I'm going run, center them in the fenders where they look right, then put a piece of round stock on the bottom of rims which will naturally find its center and run a plumb bob to the center of that, and mark the frame! I haven't found time to finish cleaning the frame up, so I can finish what they said but I'll let you know what I come up with in the end!
Guillermo Ortiz Jr.
| | | | | Joined: Sep 2013 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 21 | Just installed a speedway unit on my 53 GMC1/2 ton .The 18 1/8 measurement is from the center of hole of front shackle Bolt on frame | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Your horse is already out of the barn since the factory front axle is gone but what we do is make a plumb bob "T" pole with the leg tacked to the cowl/firewall and a plumb bob hung from each arm so the string hangs exactly through the center of the old spindles with the wheels straight. Put the new front end in with the strings in the center of the spindles and your dead on. A bonus is it leaves both hands free to juggle around what ever without using a tape. Do not change the angle of the frame till the new front is tacked in place as the change in angle throws the string off.
Evan
| | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Make sure your wheel will be centered properly in the wheel well. Do a mock up to verify. Mine worked out well, sorry I do not have the dimention handy.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
Guillermo Ortiz Jr.
| | | | | Joined: Jul 2015 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2015 Posts: 37 | Need some advise on the Speedway crossmember install
Hi I see you installed a Speedway IFS unit, was the 18.1/8 centerline measurement correct? were your wheels centered in the well.....also where do you measure center of crossmember from? I'm getting ready to install one myself. ANY help you could give would be appreciated. thanks | | |
