2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
Junior Member
Junior Member
I have a 55 TaskForce truck cab and complete bed without a frame, I what would be the best frame to use in place of the stock frame?
You could buy my 55.2 stock frame in Morgan Hill CA.
I'd vote for bones [even tho that's advertising in the garage eek ] - many later frames could be adapted, but why not find an original? that's what I did when I wound up w/ an orphan cab - any 55-59 fits w/ no mods
If you are thinking about "another" frame as in late model or something like that, rethink it. There is NO frame, NONE, that you could use without SERIOUS modifications. The time spent on "Making it work" could be spent on up dating your stock frame and it would look a LOT better when done.
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
Junior Member
Junior Member
Why do other folks add the Camaro clips to the stock frame? I want to use a 350 motor and modified 700R trans and was wondering if that stock frame could handle the power.
folks clip the frames cuz they think that's the only way to get the power steering and disc brakes they think they need, not to mention the plusher ride - they'd really prefer a car - the stock frame can handle anything you wanna put in it, and if you're worried about how well it'll stand up to high power, you can box it and add beefier motor/trans mounts - friend of mine has a 55 w/ a strong 427 and 4 speed in it [pulls the front wheels off the ground] and the stock frame has done well
