| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 18 Junior Member | | Junior Member Joined: Feb 2005 Posts: 18 | I have a 55 TaskForce truck cab and complete bed without a frame, I what would be the best frame to use in place of the stock frame? | | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | You could buy my 55.2 stock frame in Morgan Hill CA. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd vote for bones [even tho that's advertising in the garage  ] - many later frames could be adapted, but why not find an original? that's what I did when I wound up w/ an orphan cab - any 55-59 fits w/ no mods Bill | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | If you are thinking about "another" frame as in late model or something like that, rethink it. There is NO frame, NONE, that you could use without SERIOUS modifications. The time spent on "Making it work" could be spent on up dating your stock frame and it would look a LOT better when done. Brian
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Feb 2005 Posts: 18 Junior Member | | Junior Member Joined: Feb 2005 Posts: 18 | Why do other folks add the Camaro clips to the stock frame? I want to use a 350 motor and modified 700R trans and was wondering if that stock frame could handle the power. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | folks clip the frames cuz they think that's the only way to get the power steering and disc brakes they think they need, not to mention the plusher ride - they'd really prefer a car - the stock frame can handle anything you wanna put in it, and if you're worried about how well it'll stand up to high power, you can box it and add beefier motor/trans mounts - friend of mine has a 55 w/ a strong 427 and 4 speed in it [pulls the front wheels off the ground] and the stock frame has done well Bill | | |
