1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 98 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 98 | Guys, I'm swapping the original RE in my 52 3100 with a RE from an '85 Monte Carlo and a T5 tranny from an 88 Sonoma. Is there any advantage/disadvantage to using the original leaf springs vs changing to springs from say an S10 or Sonoma? I know the 1 3/4" perches will have to be welded to the RE if using the original leafs. I'd also like to drop the rear about 3". How might I accomplish that without a drop kit? As always, I appreciate the wisdom guys.
1952 Chevy 3100 Semper Fi !
| | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | The spring hangers need to match the spring width, I think this is where you will run into trouble. Late model springs are usually 2" wide and will not fit the OEM spring hangers. | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Honestly, I think that wrestling with the task of cutting off spring perches, etc and trying to re-locate the centerline of the wheel correctly using all the old shackles, hardware is not worth it. YOu still end up with 60 year old springs.
I used the spring kit from Chassis Engineering on the back of my panel truck. Everything is new, time tested, and will mate just fine with that nice Monte Carlo rear; and it will be dead centered in the wheel opening. You get new shocks, perches, pads, all the hardware. The hardest part is grinding off the rivet heads of the old mounting points. They have a bolt on and a weld on version as I recall and sell for around $400…… Dropped mine about 3 1/2 inches, but my body is LOT heavier than a pick up.
| | | | | Joined: Oct 2013 Posts: 98 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 98 | Thanks for the info guys.I think I've decided to go with a kit and the newer springs. Not sure about the Chassis Engineering vs others but will definitely check into those options. thx again for the input.
