1 members (Mike Roache), 58 guests, and 1 robot.
Topics128,078
Posts1,055,938
Members48,430
#1095762 04/06/2015 4:25 AM
Hi All, I had my truck painted a custom color some time ago and the painter is no longer available. I am looking for a paint supplier that I can send a sample of the paint to and have them match it. I would then paint the offended panel. Anyone know of a paint supplier who would match a custom paint?
If you know what type of paint was used, Your local PPG supplier should be able to match it for you.
Bring a small painted piece to the store and they will figure out the formula. For really off the wall colors They will usually keep the piece for a day and make up small samples till they get the match perfect.
If you have a PPG or DuPont dealer near you, the best bet would be to let them see a piece that has actually been on the truck, rather than a sample of the paint. That way, they can compensate for fade from the UV exposure. Had that problem last time I needed paint. When it was mixed by the code, it was too dark. Since I had the truck with me, they were able to scan a sample right off the truck and compensate for it. You can't tell what was refinished compared to what was the original paint I applied to it 10 years ago.
Bill Burmeister
