1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Hi All, I had my truck painted a custom color some time ago and the painter is no longer available. I am looking for a paint supplier that I can send a sample of the paint to and have them match it. I would then paint the offended panel. Anyone know of a paint supplier who would match a custom paint? | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | If you know what type of paint was used, Your local PPG supplier should be able to match it for you. Bring a small painted piece to the store and they will figure out the formula. For really off the wall colors They will usually keep the piece for a day and make up small samples till they get the match perfect. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you have a PPG or DuPont dealer near you, the best bet would be to let them see a piece that has actually been on the truck, rather than a sample of the paint. That way, they can compensate for fade from the UV exposure. Had that problem last time I needed paint. When it was mixed by the code, it was too dark. Since I had the truck with me, they were able to scan a sample right off the truck and compensate for it. You can't tell what was refinished compared to what was the original paint I applied to it 10 years ago.
Bill Burmeister | | |
