4 members (Otto Skorzeny, rfs56trk, Bill Hanlon, 1 invisible), 81 guests, and 0 robots.
Topics128,119
Posts1,056,313
Members48,439
#1095707 04/06/2015 12:26 AM
How many leafs should I remove from 1949 to soften up the ride a little bit, there are eight now and I removed three and it still seems pretty stiff although I have not driven it yet ( still under construction )
How do you know you need to soften the ride if the rig is still under construction? I would hold and get it on the road first.
Craig
On mine I removed every other one starting with the third leaf from the top. You need to leave the two longest ones for safety. The best thing I did for the ride on my truck was add teflon liner between each leaf, front and back.
