1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
rwb
Offline
I can turn the rear end input about 1/5 turn freely
before starts turning wheels. this is with driveline
disconnected.i have 3 trucks they all do this.
1 is a 1958 3/4 ton other 2 1959 1/2 ton
is this normal ??
thanks
Riding in the Passing Lane
That is excessive. A small amount is normal. Pull the cover off the rear & see were it is comeing from. It probably has some sloppy spider gears. They can be replaced with out pulling the 3rd member out on the 1/2 tons.
1972 Chevy c10 Cheyenne Super
Wrenchbender: Where would you get a set of spider gears? Mine are sloppy as well.
Steve H
Diff side gear splines and axle splines are notorious for wearing on these. That can add to the slop.
My Blog
