| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | I can turn the rear end input about 1/5 turn freely before starts turning wheels. this is with driveline disconnected.i have 3 trucks they all do this. 1 is a 1958 3/4 ton other 2 1959 1/2 ton is this normal ?? thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That is excessive. A small amount is normal. Pull the cover off the rear & see were it is comeing from. It probably has some sloppy spider gears. They can be replaced with out pulling the 3rd member out on the 1/2 tons. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Wrenchbender: Where would you get a set of spider gears? Mine are sloppy as well.
Steve H
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Diff side gear splines and axle splines are notorious for wearing on these. That can add to the slop.
See the USA in your vintage Chevrolet! My Blog | | |
