1 members (MickeyP),
122
Mod | | | Forums66 Topics128,088 Posts1,056,114 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 11 New Guy | | New Guy Joined: Feb 2015 Posts: 11 | So after surfing here a little bit and seeing a few things to look for on my engine, it looks like I have a 235 and not a 216 in it. I started looking at the side plate and finally scraped off the serial number, HEA is the prefix. It looks like a 1950 motor, with a 1952 cab. Any other numbers on the frame anywhere so I can see what that may be? Is this still a splash oiled 235 or were 1950 235's pressure oiled? Still learning about these, so forgive me if it's been asked before.
Thanks! | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1953 was the first full pressure 235, and that was only in cars with Powerglide transmissions. Trucks started in 1954.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2015 Posts: 11 New Guy | | New Guy Joined: Feb 2015 Posts: 11 | Aaah, thanks guys. I wasn't positive when the transition was. | | | | | Joined: Oct 2008 Posts: 48 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 48 | 1953 was the first full pressure 235, and that was only in cars with Powerglide transmissions. Trucks started in 1954. I have had an old 6 lying about on our property for a while now that my dad picked up while doing his '53 car project. It has the older (216) style water pump port arrangement but is obviously not a splash oiler (no "Tenneco sign" shaped plate)and it had the 4 side screw valve cover. The casting numbers say it is an late '53- early '54 model engine. This engine has a manual transmission car bell housing attached- seemingly precluding the idea that it had a Powerglide. The question is... what did this come out of? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The older style water pump was used in 1954 in cars and trucks, and in 1955 first-series trucks.
Post the engine serial number (pressed into the block, to the rear of the distributor) and the year/model and car/truck can usually be distinguished.
