6 members (Bill Hanlon, Gdads51, Otto Skorzeny, UtahYork, dt235sd, Ponchogl), 115 guests, and 5 robots.
Topics128,089
Posts1,056,130
Members48,435
#1095410 04/04/2015 3:40 AM
So after surfing here a little bit and seeing a few things to look for on my engine, it looks like I have a 235 and not a 216 in it. I started looking at the side plate and finally scraped off the serial number, HEA is the prefix. It looks like a 1950 motor, with a 1952 cab. Any other numbers on the frame anywhere so I can see what that may be? Is this still a splash oiled 235 or were 1950 235's pressure oiled? Still learning about these, so forgive me if it's been asked before.
Thanks!
HEA is the preface for a big truck engine - 5000/6000 series.
That would be a low-pressure 235 engine (truck 235s were low-pressure through 1953).
1953 was the first full pressure 235, and that was only in cars with Powerglide transmissions. Trucks started in 1954.
My Blog
Aaah, thanks guys. I wasn't positive when the transition was.
I have had an old 6 lying about on our property for a while now that my dad picked up while doing his '53 car project. It has the older (216) style water pump port arrangement but is obviously not a splash oiler (no "Tenneco sign" shaped plate)and it had the 4 side screw valve cover. The casting numbers say it is an late '53- early '54 model engine. This engine has a manual transmission car bell housing attached- seemingly precluding the idea that it had a Powerglide. The question is... what did this come out of?
The older style water pump was used in 1954 in cars and trucks, and in 1955 first-series trucks.
Post the engine serial number (pressed into the block, to the rear of the distributor) and the year/model and car/truck can usually be distinguished.
