| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 37 | I dont know if this is the right place to ask about this problem because its not a GM problem but some one may be able to help. I have a 53 Jeep M38A1. I got this Jeep after it had sat for some time and when i started it the RMS"rear main seal" leaked.It had a neoprene seal so i replaced it. It leaked so i was told that a rope seal may hold better so i pulled the engine and put one in.It leaked. I now fill like i did a rush job with the rope seal. The engine was rebuilt and had low miles but has sat so the crank is good as are the main bearings. I have a 46 jeep thats engine had 0 miles when i got it. Its RMS leaked. I replaced it and it didnt help.I did a frame off rebuild and replaced the RMS and it stoped leaking.I thought maybe it had alot of crank case presser but it dosent. I have worked as a mechanic on and off for 40years and replace RMS on alot of diffrent kinds of engines and never had a problem.I want to drive it this summer but i dont want to repeat the past.I am thinking about trying another rope seal.What would you do? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you did not put a tiny amount of sealer on the brg,. cap from the edge of the seals out it could be leaking between the block & cap. If the flywheel bolts go into thewet side of the crank it can leak through the bolt threads. You will need some sealer on them. The plug at the rear of the camshaft can leak & be mistaken for a RMS. I prefer the rubber type seal when available. I don't mind questions about other makes as long as it is not a foreign vehicle. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Most people have forgotten (or maybe didn't know in the first place) that rope seals need to be thoroughly soaked in oil before installation. The oil helps the fibers swell up and make a smooth, tight seal against the crankshaft. I soak rope seals overnight in clean 10W-30 motor oil before installing them. Jerry
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Rear main seals are kind of an age old problem on Willys vehicles. I have experienced the frustration of working on them in the military and later on my own vehicles and in shops. The last one I replaced on an M38 was a neoprene seal and it has lasted for several years. I have also found that parts offered by some of the military suppliers are NOS and could be 50 years old. In some cases parts have been so hard or brittle they don't work very well. Midwest Military and Ron Fitzpatrick are good sources. Fred
| | | | | Joined: Nov 2014 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 37 | I think i will pull the engine and maybe presserise the oil system while its out and let it set at a angle to see if it will leak. Fred i have heared about the RMS they are a problem I wonder why? I like old orignal jeeps but if this jeep didnt have a engine i wouldnt look for one like it has. | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Rear main bearing seals are not exposed to pressurized oil- - - -splash only! Be sure the drain holes back into the pan are clear and the tip about using Permatex between the main cap and the block is a good one. Jerry
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Make sure that it is the rear main seal that's leaking. I had a serious leak from the front of the transmission on my 47 CJ2A. It's different oil but basically leaks from the bellhousing in the same location as the rear main. They could both be leaking. Fred
| | | | | Joined: Nov 2014 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 37 | Make sure that it is the rear main seal that's leaking. I had a serious leak from the front of the transmission on my 47 CJ2A. It's different oil but basically leaks from the bellhousing in the same location as the rear main. They could both be leaking. Fred Its engine oil for sure. What made your trans leak?I am thinking about starting it up on the ground after i replace the seal. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | It was overall sloppy but I discovered later that it needed a full gasket between the trans and the bellhousing. It was mostly the cluster gear shaft/case leaking. Later units only used the gasket behind the bearing retainer. My 2A has a "F" head engine same as your 38A1 but it didn't leak too bad so I left it alone. Fred
| | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | If possible use a seal from Best gasket company. They sell rope that really works, like the old stuff did.
Joe
| | | | | Joined: Nov 2014 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 37 | I drove it some the last 2 summers like this but i let the license run out telling my self i wouldnt put it back on the road untill i fixed it. I have 3 prodjects ahead of it. My dads tractor needs rewired,my 61 F600 has a rear hub leaking oil and i bought a Case skid steer that needs a engine.Its sometimes overwhelming haveing so many old rigs i may thin them out some. | | |
