2 members (baldeagle, homer52),
36
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 579 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 579 | For those who follow the BillyBob adventures, I've just posted a new log entry dealing with the rebuilding of the passenger side vent window assembly. It's a little tedious (especially for me) since I made a lot of mistakes. Anyway, here's the link: BillyBob Update - Two-Forty A/C | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Always look forward to Billy Bob (first found the bolt by looking at Billy Bob site  )
| | | | | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Great Report Larry with all the details.. Thanks for putting it up..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
| | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Hey, Larry, nice job! I also had a gap between the vent glass and vertical channel when it closed, except I set both the window in the frames at the same time. Only found the 1/4" gap after the fact. :mad: After doing some serious thinking, I came up with a simple and (if I may say so myself) rather elegant solution: You know that bladed strip of rubber that goes in a slot at the top of the door panel, which presses against the outside of the window and acts sorta like a squeegie when you roll the window down? If you cut it in half, it's precisely the length of the flat edge of the vent glass. Remove the riveted rubber seal from the vertical post and glue the blade in it's place. No gap, no leak, no wind noise; and I didn't have to pull the vent windows out of the frames and start over. So far, nobody has even noticed that it's not correct, although I have gotten kudos on the tight seal from passengers. Of course, if you're aiming for a perfect resto, you'll probably want to pull the glass and start again. I was more concerned with keeping the rain out of my face.  | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | I like how the chroming stuff looks. It looks like a nice looking original chrome job that's seen 50 years of abuse. A little faded, maybe add a few scratches for good measure. Lookin' good Larry. (this takes on new meaning for me as the '45 is a DRIVER)  | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Wow, I also found this website through Billy Bob. Billy Bob is what made me want to get one myself. And now I am famous.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Larry - those rivets are a pain to set I agree. I ended up just mashing mine over with the smooth part of the vise after driving a punch into it to get the mushroom started. I didn't spring for the tool. Speaking of springs, what's the story on that vent spring? No way to cut the new in half and do both windows with one...lol?
I hope that you are planning on publishing this book when you are all done. You can put "How to restore your Chevy Pickup" out of business! | | | | | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | Larry - I really enjoy your writeups. Two things strike me.
1) It's nice to know someone else gets as big a kick out of buying new tools as I do. When you and I die they're gonna have a helluv a good garage sale!
2) If I had to put up with that much rain they'd have to put me on medication.
PRW | | | | | Joined: Jul 2000 Posts: 579 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 579 | Many thanx, as always, Luke, Bill, Hedge, K10, Tony, Kook and Paul.
That gap solution looks real interesting, Hedge. Gonna look into that. I already have the strip you're talking about up at the warehouse.
Gonna revisit the hinge rivet with the vise too, Kook, Thanx. I do think the spring could be made into two of the proper size if you could rig a jig for a good clean straight cut.
If I ever put this into book form the title will be "How to make a small fortune restoring an old truck . . . Start with a big fortune!"
Paul, I keep myself sane when it rains by repeating quietly to myself "At least I don't have to shovel this stuff." | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | How about: "Restoring antique trucks for dummies" It kind of fits the Krashlab computer theme...
| | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | Larry, good site! I just seated my wing window rivets two days ago. I used a cold chisel and clamped the chisel end in my vise. The handle end fit perfect into the cat whisker channel for the back side of the rivets. Just balanced the frame over the chisel and whacked it a couple of times. Flattened then out fine using a punch and hammer. Came out nice and tight. | | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | Larry how about this title "How to make it rich restoring old truck" sub titled " A tool suppliers success story"!
Once again thanks for documenting your trail and tribulations for all of us.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Sep 2003 Posts: 29 'Bolter | | 'Bolter Joined: Sep 2003 Posts: 29 | The substitute rubber seal is a good idea. But do people have experience with installing reproduction vent glass? It seems that the "gap" problem is mentioned in several postings I have seen, and the repro glass I bought (2 different vendors) seems to be almost impossible to seat in the frame and avoid having the gap. I understand that you don't need to jam the glass all the way into the frame, but in order to eliminate the gap, it seems like the glass needs to be almost out of the frame.
Or maybe the problem is the repro rubber that rivets on the frame - is it too short, and so doesn't meet the glass? | | |
