0 members (),
86
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | I have a 1958 3/4 ton longbed very good cab and clip. took bed off as was bad.so I have a pretty good short bed fleetside bed.is it feasible to cut the 9.5 inches out of the frame behind the cab to make it a shortbed ?? then cut rest off back.
| | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | Might be cheaper and a lot less effort to find a short bed truck frame $300 or a long stepside bed for 3-400.
If you cut your frame you need to cut your drive shaft and run new brake lines. Also you might be limiting potential buyers if you decide to sell. It is your truck so only you can really answer that question. | | | | | Joined: Mar 2010 Posts: 10,303 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,303 | Also, there are folks out there looking for long frames. It would be a shame to kill one of what they don't make any more. Carl
