6 members (GRNHydra, Ponchogl, JW51, Forty9, Shardean, SWEET), 64 guests, and 5 robots.
Topics128,021
Posts1,055,349
Members48,420
#109404 10/19/2004 9:54 PM
Junior Member
Junior Member
I really like a classic half done hot rod look, primer. I am wonder what products/paints are out there to keep a primer/flat finish. Is Epoxy primer the answer?
#109405 10/19/2004 9:58 PM
I believe it is actually BC/CC with a flatening agent used in the clear to kill the gloss.
#109406 10/19/2004 11:16 PM
There is no panacea one coat primer/paint. The way to protect it properly is to epoxy prime, then base coat (black or gray or whatever), then clearcoat with a flattening agent. The primer is not water or UV resistant and the base coat is UV resistant but not water resistant and will not stick to bare metal. The clear is water/uv resistant.
Paint & Body Shop moderator
#109407 10/20/2004 3:24 PM
Can you just put clear with a flattening agent over black primer? Do you need a base coat?
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
#109408 10/20/2004 6:16 PM
The base coat provides UV resistance. It keeps the primer from fading in the sun.
