| | | Forums66 Topics128,021 Posts1,055,348 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 16 Junior Member | | Junior Member Joined: Oct 2004 Posts: 16 | I really like a classic half done hot rod look, primer. I am wonder what products/paints are out there to keep a primer/flat finish. Is Epoxy primer the answer? | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | I believe it is actually BC/CC with a flatening agent used in the clear to kill the gloss. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | There is no panacea one coat primer/paint. The way to protect it properly is to epoxy prime, then base coat (black or gray or whatever), then clearcoat with a flattening agent. The primer is not water or UV resistant and the base coat is UV resistant but not water resistant and will not stick to bare metal. The clear is water/uv resistant.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | Can you just put clear with a flattening agent over black primer? Do you need a base coat?
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The base coat provides UV resistance. It keeps the primer from fading in the sun.
