4 members (TexasJim50, 3B, Otto Skorzeny, 1 invisible), 66 guests, and 8 robots.
Topics128,013
Posts1,055,322
Members48,419
#109357 05/01/2003 11:03 PM
hey im really new to this (im only 15) and my 68's a rust bucket. id really appreciate someone telling me how to get rid of body panel rust, cab rust anything just the best way to go about getting rid of rust...period. thanx
#109358 05/02/2003 12:37 AM
Welcome to the 'bolt!
It all depends on your budget, facilities, and severity of the rust. I tore down the body completely and went after everything with a wire cup brush on an angle grinder (keep moving or you'll warp the steel). Then I hosed everything with Rust-Mort (phosphoric acid), washed it down and dried it, and shot primer everywhere before surface rust came back. Most primer is not going to seal moisture out, so get some paint on it before leaving it in the rain.
Those with better facilities can set up a blast booth and glass bead (sand is not recommended) the body panels; I didn't have that luxury. Those with bigger budgets can have the body "dipped;" also out of my range so I didn't research it too deeply.
Do a search in this forum, and check the Tech Tips link at the top of the page. There are as many approaches to this problem as there are rusty Stovebolts. grin
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#109359 05/02/2003 2:58 AM
Welcome to the 'Bolt 68Custom... from a fellow Winnipegger too. You've found the right place to ask any and all of your questions, these guys know it all (and if they don't, they can make you believe that they do wink ).
Lorne
MbOutdoors (Lorne)
1952 Chev 1300
#109360 05/02/2003 4:15 PM
Rust is that brown stuff right? Sorry, don't have any... :p
54 3100 with 235
62 flatbed dump C60 with 261
#109361 05/03/2003 5:54 AM
hey thanx i appreciate your help. and just for your interests sake im one of the low budget guys...im so happy i found people who know what there talkin about (i hope) thanx again.. l8a
#109362 05/06/2003 4:06 AM
Junior Member
Junior Member
I blasted most of mine out, but I did use OSPHO to convert some of it. The only problem with the converters is that it does not leave a smooth enough surface for painting, lots of primer and filler to smooth out.
54 1ton
#109363 05/07/2003 7:24 PM
68, I forgot to mention if you are looking at picking up some ZeroRust, there is a distributor here in Winnipeg. They are called ABS wharehouse and are located at 1368 Border St. phn: 694-2879.
Lorne
MbOutdoors (Lorne)
1952 Chev 1300
