2 members (carbking, RLB), 157 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#109339 03/13/2005 6:51 PM
Need some info about the exterior door locks. Mine is a 49----turn down handle. Bought a new lock and key from the vendors, installed it but I can't get it to lock or unlock the door. Any ideas. Would they originally lock the mechanism with the key or did you have to shove the interior handle forward before getting out and slam the door? Any help or thoughts would be appreciated.
#109340 03/14/2005 12:31 AM
I can't say for sure about the '49, but on the '51-'55 the door will not latch if you lock it from the inside first. There are two separate locking mechanisms. The inside one locks the latching apparatus and the key one locks the button on the outside handle. They are not made to be used together.
#109341 03/14/2005 8:12 AM
The turn down handles should lock and unlock with the key, but they do need to be adjusted properly to work.
Paint & Body Shop moderator
