3 members (Danielbolt, bluechev, 1 invisible), 104 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
#1093095 03/23/2015 3:15 AM
Can someone tell me the bolt size for the hood latch on a Chevy 3100?
1 is 1/4 x 20, but the other 3 are something else. The nuts that are welded oo appear to be original.
David
1952 Chevy 3100
It has been a while but I don't think there were any welded bolts on the truck. They usually are captive.
1951 1 Ton Completed
There are 4 nuts attached to the underside of the latch panel. These appear to be original. Are those called captive?
David
1952 Chevy 3100
There are four 'cages' spot welded to the underside of the upper
baffle, the nuts are loose and held in place by folding in the
four sides of the cage. So yes, they are a captive 1/4-20
square nut. The original screws would have been 1/4-20 x 1/2"
binding head clutch drive screws.
http://www.pbase.com/dennygraham/image/159522304
dg
Denny G
Sandwich, IL
Update on the hood latch bolts. A PO had welded some size nuts (must have been metric). I solved the problem with a 1/4 x 20 tap. thanks for the help Denny.
1952 Chevy 3100
