0 members (),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 195 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 195 | Hey, found a cheap electric water temp gauge with sensor that I'm going to use in my truck. it has a 1/8" NPT sensor. I guess its way too small, but what size should be used on my 216 engine? So i can buy an adapter.
Cheers! Chevrolet 3100 Year: 1951 engine: inline 6 217CI Transmission: Manual 3-Speed. 12Volt. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Way too small for what? Adapt it (if necessary) to wherever you are going to mount it. The thread size has no bearing on operation. As long as the "probe" reaches water it will send a signal. I'm sure you will get advice as to what others did on their 216's shortly.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2014 Posts: 195 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 195 | On the driverside of the engine, there is a threaded opening where my old temp sensor was installed, i think its 5/8". But i am not sure. The new sensor would be 1/8" so thats to small too fit in that opening.
I want to be sure about the size so i buy the right adapter. I'd like to use the same opening as usual. Chevrolet 3100 Year: 1951 engine: inline 6 217CI Transmission: Manual 3-Speed. 12Volt. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | 5/8-11 5/8-18 to 1/8 pipe I could not find one so I had to make one out of a 3/8pipe to 1/8 pipe brass bushing ...pic... I Just ran a die nut on the adapter and cut the straight threads | | | | | Joined: Mar 2014 Posts: 195 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 195 | Allright, I hope i can make it work. so it is 5/8 inches then. What doest "11" stand for? Chevrolet 3100 Year: 1951 engine: inline 6 217CI Transmission: Manual 3-Speed. 12Volt. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Size
Threads per inch
I'll make a correction
Looking at the pic looks like 5/8-18 on the die nut
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The main thing is that the sender resistance matches the gauge. I dought if that one will work with a factory gauge. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2014 Posts: 195 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 195 | I can't find one on eBay.. I don't like amazon. The main thing is that the sender resistance matches the gauge. I dought if that one will work with a factory gauge. I wrote that i found a gauge with sender, only problem is the senders connection size, so the resistance is no problem. Chevrolet 3100 Year: 1951 engine: inline 6 217CI Transmission: Manual 3-Speed. 12Volt. | | | | | Joined: Mar 2014 Posts: 195 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 195 | Yeah so, from Amazon i got this, as usual: "Sorry, this item can't be shipped to your selected address. Learn more. You may either change the shipping address or delete the item from your order." Is THIS one right? UNF? thisone is also UNF and says "18". darn shipping is like 3 times more than the adapter itself. so stupid that this will cost more than the gauge and sender combined. Chevrolet 3100 Year: 1951 engine: inline 6 217CI Transmission: Manual 3-Speed. 12Volt. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Is THIS one right? UNF? thisone is also UNF and says "18". Yes that is the correct size | | | | | Joined: Mar 2014 Posts: 195 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 195 | Okay, i'll ask the other seller what his shipping costs are and then buy the cheapest! Thanks a lot DADS50! Once again! Chevrolet 3100 Year: 1951 engine: inline 6 217CI Transmission: Manual 3-Speed. 12Volt. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I could not find one so I had to make one out of a 3/8 pipe to 1/8 pipe brass bushing ...pic... I Just ran a die nut on the adapter and cut the straight threads I might be faster and cheaper to make one. That is if you can come across a bushing and a die nut "over there". | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | It would also be possible to use a short 5/8-18 bolt, and drill and tap the bolt head for a 1/8" NPT thread. Use a copper washer from a brake caliper flex line fitting as a gasket between the bottom of the bolt and the sensing bulb seat in the cylinder head. Jerry
| | | | | Joined: Mar 2014 Posts: 195 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 195 | Yeah that Would have been nice but my tools are metric only..
Edit: I now ordered one.
