Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (1955 1 Series, farmallb, TooMany2count), 65 guests, and 1 robot.
Topics128,006
Posts1,055,272
Members48,418
#1092766 03/21/2015 3:24 PM
Hey, found a cheap electric water temp gauge with sensor that I'm going to use in my truck. it has a 1/8" NPT sensor. I guess its way too small, but what size should be used on my 216 engine? So i can buy an adapter.
Cheers!
Chevrolet 3100
Year: 1951
engine: inline 6 217CI
Transmission: Manual 3-Speed.
12Volt.
Sir Searchalot
Sir Searchalot
Way too small for what? Adapt it (if necessary) to wherever you are going to mount it. The thread size has no bearing on operation. As long as the "probe" reaches water it will send a signal. I'm sure you will get advice as to what others did on their 216's shortly.
On the driverside of the engine, there is a threaded opening where my old temp sensor was installed, i think its 5/8". But i am not sure. The new sensor would be 1/8" so thats to small too fit in that opening.
I want to be sure about the size so i buy the right adapter. I'd like to use the same opening as usual.
Chevrolet 3100
Year: 1951
12Volt.
5/8-11 5/8-18 to 1/8 pipe
I could not find one so I had to make one out of a 3/8pipe to 1/8 pipe brass bushing
...pic...
I Just ran a die nut on the adapter and cut the straight threads
Allright, I hope i can make it work. so it is 5/8 inches then. What doest "11" stand for?
Chevrolet 3100
Year: 1951
12Volt.
Size
Threads per inch
I'll make a correction
Looking at the pic looks like 5/8-18 on the die nut
Riding in the Passing Lane
The main thing is that the sender resistance matches the gauge. I dought if that one will work with a factory gauge.
1972 Chevy c10 Cheyenne Super
Originally Posted by DADS50
I can't find one on eBay.. I don't like amazon.
I wrote that i found a gauge with sender, only problem is the senders connection size, so the resistance is no problem.
Chevrolet 3100
Year: 1951
12Volt.
Yeah so, from Amazon i got this, as usual:
"Sorry, this item can't be shipped to your selected address. Learn more. You may either change the shipping address or delete the item from your order."
Is THIS one right? UNF?
thisone is also UNF and says "18".
darn shipping is like 3 times more than the adapter itself.
so stupid that this will cost more than the gauge and sender combined.
Chevrolet 3100
Year: 1951
12Volt.
Yes
that is the correct size
Okay, i'll ask the other seller what his shipping costs are and then buy the cheapest! Thanks a lot DADS50! Once again!
Chevrolet 3100
Year: 1951
12Volt.
I could not find one so I had to make one out of a 3/8 pipe to 1/8 pipe brass bushing...pic...
I might be faster and cheaper to make one. That is if you can come across a bushing and a die nut "over there".
H Online: Content
It would also be possible to use a short 5/8-18 bolt, and drill and tap the bolt head for a 1/8" NPT thread. Use a copper washer from a brake caliper flex line fitting as a gasket between the bottom of the bolt and the sensing bulb seat in the cylinder head.
Yeah that Would have been nice but my tools are metric only..
Edit: I now ordered one.
Chevrolet 3100
Year: 1951
12Volt.
