| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | I know I saw a post on how to stop water from coming through the cowl vent (when closed) from getting into the cab. I have a gasket on it but it still leaks. No rusted hole or anything like that. Does anybody have that link or remember what to do? As always, thanks. Steven | | | | | | Neverdone Unregistered | | Neverdone Unregistered | Red
I am guessing you checked the obvious , the drain hole and tube .
How well is it seated , it is possible that it is slightly twisted . You may put something on the rim [ grease / lipstick etc]of the vent and close it tight , open it back up and see if it transfers all the way around Dan | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Red49truck, I don't have the link but on most trucks the cowl vent handle has a spring to keep it closed tight. Does your's have one? Should it? ....and what type of material is your gasket? Had a "rubber" one that leaked because it wasn't soft enough for the vent to seal. I changed to a cork gasket and problem solved as the vent would "sink" done in it and seal it off tight....and my 37 had a spring on it to keep it tight. Not sure about your 49. | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | I'm not sure about the spring but the gasket is made out of some kind of foam. I'll get a cork gasket and put some light grease around the top and make sure it seals all the way. Thanks everyone for the tips. Steven | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | As soon as I get the gasket I'll write back. | | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | I have the same problem on a '53 that had body and paint work and have a fairly new replacement rubber gasket. I see that Classic Parts sells both a rubber one or a foam one. Has anyone used both and can say which they prefer? I also note that the new bolts that are being used to secure the hinges are fairly small and it looks like they should be larger based on the holes. Does anyone have an original to tell me the correct size? John Hill | | |
